rickeagle | -- 12-16-2017 @ 10:22 AM |
I want to put 3 point belts in the front seat of my '40. Anyone done this? There appears to be plenty of room to put shoulder belt pivot point in the B pillar and a mount area at the floor or base of door frame for retractor. Any info appreciated!
40cpe | -- 12-16-2017 @ 12:54 PM |
I did it in the early '90s. If I remember correctly the "B" pillar sheetmetal meets under the upholstery on the pillar. I welded a nut to a steel plate and welded the plate inside the "B" pillar, attached the upper belt swivel to the nut. I wasn't impressed with the amount of steel there was to weld to. I don't know if this setup has been tested, but we were fortunate to drive all over the southeast every summer for 20 years and not have to test them.
larryb346 | -- 12-16-2017 @ 6:42 PM |
I have installed them in my 39 coupe I used a b pillar mount from Julianos street rod parts and seat belts. Here is a link to the piece I used it worked perfect and very easy http://www.julianos.com/No-Weld-B-pillar-Bracket-for-35-48-Ford-p/ju010955.htm good luck Larry
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11489 |
