MICHV8 | -- 12-02-2017 @ 5:47 AM |
59AB shows a few drops of anti-freeze out of open exhaust manifold after running for 10 minutes. Assuming it is not a head gasket leak and the oil shows no sign of moisture, would I have any chance of correcting that leak short term with a stop leak (such as Bars)? The engine only has 55-70 psi in 5 cylinders and 0 psi in the other 3, so it is due for a complete rebuild anyway, but being able to move it around would be helpful in the interim... Thanks to all who have posted replies in the related threads. This message was edited by MICHV8 on 12-2-17 @ 5:47 AM
cliftford | -- 12-02-2017 @ 6:52 AM |
If you just need to be able to move it around, I would put a drip pan under it and not try to stop the drip.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11447 |
