Topic: What is it called and does anyone reproduce them?
Ritzy1    -- 11-29-2017 @ 3:14 AM
  Does anyone re-manufacture this piece of metal that screws into the floor at the door sill on a 48 Tudor Sedan? Not sure what it's called. It appears to hold the carpet in and maybe provide a place to hide wires running to the rear of the car. As you can see, mine is partially rusted away (yes, so is the floor). Please disregard the non-stock wiring.
Thanks, Dave
ken ct.    -- 11-29-2017 @ 3:57 AM
  Door sills,not sure if they are being repoed,but the yrs that are not quite like originals. ken ct.
nelsb01    -- 11-29-2017 @ 4:36 AM
  They are called door scuff plates --- google Dennis Carpenter -- he has them
Ritzy1    -- 11-29-2017 @ 7:11 AM
  Thank you so much! Unfortunately, it looks like whoever was manufacturing them is no longer. I tried all of the usual suspects and no one has them in stock.
trjford8    -- 11-29-2017 @ 8:08 AM
  Continue to call around. Try All Ford Parts in Campbell, Ca. or the Early Ford Store in San Dimas, Ca.
Drbrown    -- 11-29-2017 @ 11:50 PM
  The sill plates/trims in my '47 doorways, which appear to be OE, are formed sheet stainless steel, as many trims on the car are. Don't know if your OE would be same. A sheet metal worker could make them if he's given the profile and measurements. I could give you info on mine. Should be similar or same.
MICHV8    -- 11-30-2017 @ 5:13 AM
  Maybe Baxter in Kansas?
Topic: https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11438
