pmonty | -- 11-26-2017 @ 11:56 AM |
I have had a lot of problems in getting the horns to work consistently. Having redone the wiring and next the relay I have discovered that one horn works most of the time and the other seldom works. Took the cover off the back and there is quite a bit of corrosion. Questions- Is it a simple thing to dismantle them and clean up and reset or should I find a horn rebuilder? Has anyone got a set that works perfectly and would sell it? There is a rebuilder in Wisc. but he works on 12v post war. I need pointers on diy or have rebuilt or buy . pmonty
mrtexas | -- 11-26-2017 @ 6:40 PM |
Sand the points and reset the horns. They will work. Mine did. This message was edited by mrtexas on 11-26-17 @ 6:41 PM
pmonty | -- 11-27-2017 @ 11:54 AM |
Did you take everything apart or only the points. Most parts are rusted. pmonty
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11424 |
