billcarry | -- 11-22-2017 @ 11:53 AM |
Regarding the hose that goes from the firewall to the lower radiator hose on my 48: is it routed in a partiular way? Does it have any supports or brackets associated with it?
supereal | -- 11-22-2017 @ 2:02 PM |
There are two clamps that hold the hoses, and are placed about mid way between the firewall and the radiator. They are part number 91A-15151/2 in the kit from C&G (800/266-0470) They connect the hoses to the spark plug wire looms. Many were lost over the years. The kit sells for about $50.
Drbrown | -- 11-22-2017 @ 10:25 PM |
Incidental note re distributor caps ..... there is a circular gasket available which goes between the cap and distributor body. Although it provides some resistance to water/dirt entry into the distributor, its usage appears to have been lost in the passage of time .... some saying it is not needed. Its still available.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11406 |
