ibshane | -- 11-03-2017 @ 6:05 AM |
I am getting ready to put fresh plugs in my 1937 Model 78 V8-85 The current plugs are "Champion UD16" Is this a good plug? Or is there a particular plug that has proven out to be better for this engine? Thanks Guys!
ken ct. | -- 11-03-2017 @ 9:48 AM |
I have a 36 and use Champ "D-21" which are slightly hotter plug. Been using for past 20 yrs. , I assume these are 18 mm plogs. ken ct
ibshane | -- 11-03-2017 @ 9:37 PM |
Thanks ken ct, Yes..., mine are 18mm in cast iron heads. I finally found online that Champion #7 was the original plug for the '37 V8-85 which cross-references to: Champion D16 Autolite 386 NGK AB-6 (2910) and a bunch of others. Is the Champion D-21 a hotter plug than what is spec. for your '36? If so....., Is there an advantage to using a hotter plug?
ken ct. | -- 11-04-2017 @ 12:59 AM |
Cant answer your question on specs, but 21's run much cleaner than the 16's. Same spec I would assume. Try a set you will like them. ken ct Been using them for like 20 yrs and 40,000 miles. NGK's suck.
ibshane | -- 11-04-2017 @ 1:13 AM |
Might have to give the D-21 a try. The UD-16 plugs that came out do look pretty fouled! Thanks!
TomO | -- 11-04-2017 @ 7:20 AM |
A hotter plug is needed when a car is driven at low speeds only. If most of your driving is less than 40 mph, use a hooter plug. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11347 |
