MICHV8 | -- 10-31-2017 @ 7:44 AM |
Does the 1939 voltage regulator (51A-10505) need the rubber pads or can is sit right on the firewall? Thanks! This message was edited by MICHV8 on 10-31-17 @ 7:48 AM
kubes40 | -- 10-31-2017 @ 8:05 AM |
51A is NOT a '39 voltage regulator although it will function properly. Yes, you should install the pads. The rubber pads insulated the regulator from the dash panel a bit while still offering a ground through the internal sleeves. Mike "Kube" Kubarth
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11338 |
