firetruckjack | -- 10-07-2017 @ 3:34 PM |
I am trying to research a 1938 Ford fire engine that was built on a 2 ton chassis. I cannot find any good info about the 2 ton chassis.
alanwoodieman | -- 10-07-2017 @ 5:22 PM |
I have a 41 fire engine cab/chassis 1 1/2 ton and a friend has a 41 3 ton ex fire engine and the only differences we see are extra spring leaves and a doubled frame from under the cab to the rear axel. my 41 was a 500 gallon pumper with mid mount pump, his was a front mounted pump and 750 gallon tank
firetruckjack | -- 10-07-2017 @ 5:25 PM |
It seems that any data beyond 1 1/2 ton is missing. Is the engine the same with all of the same hp and torque values? The engine has the 24 bolt heads.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11257 |
