W1964 | -- 10-01-2017 @ 7:46 PM |
Similar to JT's issue, my speedometer works but NOT the Odometer. What should I check. Thanks. Bill 1939 Coupe Deluxe
TomO | -- 10-02-2017 @ 7:17 AM |
The speedometer needs to come out for inspection. You may be able to get the odometer working by lubricating the pivot point for the gears, but most likely, it will have to be repaired. Tom
Drbrown | -- 10-02-2017 @ 9:08 PM |
Will a '47 odometer part fit your unit ? I have the shaft complete with gear, bearings and numerical wheels/dials.
supereal | -- 10-03-2017 @ 2:20 PM |
We send speedometers and other gauges to Bob's Speedometer in Michigan. They will inspect yours and give a cost to restore it. They also have a stock of speedometers and gauges in stock. They found a NOS speedometer for my '47. There phone number is 1-800-592-9673
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11239 |
