autoluke | -- 09-29-2017 @ 9:40 AM |
Having a problem when tightening the steering wheel on the shaft during wheel installation. With the nut tightened only within 1/4" of the correct position, can not budge the wrench. Any suggestions ?
3w2 | -- 09-29-2017 @ 3:18 PM |
How about a thread chaser for both the nut and the shaft?
trjford8 | -- 09-30-2017 @ 7:06 AM |
Sure you have the right size woodruff key?
supereal | -- 09-30-2017 @ 1:27 PM |
The fine threads are often damaged when the correct puller isn't used or someone has hammered on the shaft to get the wheel off. I agree with my friend Tom about the key. Forcing the nut can damage or destroy the threads, as can a common die instead of a thread chaser.
3w2 | -- 09-30-2017 @ 4:42 PM |
Also, if your car is pre-'40, make sure that the bottom of the woodruff key is flat otherwise it will bite into the light switch rod inside the steering shaft.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11228 |
