artron9 | -- 09-22-2017 @ 3:56 PM |
Why am I having trouble with the search site? After I enter my search topic, and submit, everything disappears and it says 0 items!
efv8CofAAdmin | -- 09-22-2017 @ 6:17 PM |
Besides your topic, you also need to change the In the Past parameter. Most change it to 365 or All Web Administrator
artron9 | -- 09-22-2017 @ 7:01 PM |
Thank you for your assistance! I will try again.
artron9 | -- 09-22-2017 @ 7:08 PM |
Just tried again with no luck: Halogen lights 365 all forums artron9
artron9 | -- 09-22-2017 @ 7:15 PM |
I cant believe I'm the only one with Halogen lighting concerns? Still cant get a response with the Search bar!
CharlieStephens | -- 09-22-2017 @ 7:42 PM |
Try searching for "halogen" only and try "all" dates. What year vehicle are you are working on? If it is pre '39 and is 12 volts check out the "brite" bulbs from Ron Francis Wire Works, https://www.ronfrancis.com, (800) 292-1940. I have these in my '32 and they go into the original sockets. Charlie Stephens This message was edited by CharlieStephens on 9-22-17 @ 7:51 PM
len47merc | -- 09-23-2017 @ 3:06 AM |
Artron9 - do not enter your or anyone else's username unless you are looking for something specifically posted by you or them. The search criteria you are using is limiting your results to only posts made by YOU in the last 365 days, so you have not posted anything referencing 'halogen lights' in that time period. In addition to not entering a username, change your timeframe to 'All' for more results. Lastly, also search for 'dim headlights' as well. Steve This message was edited by len47merc on 9-23-17 @ 3:23 AM
artron9 | -- 09-23-2017 @ 6:19 AM |
Thank you webmaster, Charlie Stephens and Lens47 merc. Success! All of your suggestions worked for me ! Again the Ford Maniacs come through! Sincerely Ron
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11203 |
