SUPERTOOL | -- 09-17-2017 @ 3:30 PM |
As a general rule when you are bolting the fenders, inner fenders etc. do you have the hex head of the bolts showing as you look under the fender or the nuts?
nelsb01 | -- 09-17-2017 @ 3:44 PM |
I know this answer --- thanks to Mr. Don Rogers................ The bolt heads are inside the frame -- so the nuts and washers are visible as you look into the fender from the outside. I forgot to take good notes when disassembling, but it makes sense.
ford38v8 | -- 09-17-2017 @ 4:00 PM |
Bruce, I'm pretty sure I understand your explanation, but I think I might be able to clarify it for others: The bolts drop in from the top when appropriate, which makes the task a one man job. Alan
nelsb01 | -- 09-17-2017 @ 8:51 PM |
Well Alan, I will tell you that I did have to use a box end wrench on the bolt heads to make sure they were secure. I am sure that the assembly employees used a high speed tool to tighten them up without the wrench on the inside, but that's the difference between a personal restoration and the need to get them out the door and sold.
SUPERTOOL | -- 09-19-2017 @ 8:05 AM |
Thanks guys. I was having a devil of a time trying to get nuts and washers on inside the frame rail!
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11189 |
