snoozer | -- 09-14-2017 @ 1:54 PM |
I'm working on a vacuum trico windshield wiper motor, cleaning it ,removing years of gunk from inside, and going back together . Does anyone know what lubrication is used in it and how much is required.
4dFordSC | -- 09-15-2017 @ 9:22 AM |
https://www.mafca.com/downloads/Technical/Lubricating%20the%20Trico%20Vacuum%20Wiper.pdf Google is your friend.
snoozer | -- 09-15-2017 @ 12:34 PM |
Thank you for the info , very informative
TomO | -- 09-16-2017 @ 7:51 AM |
When you have the motor apart, you can use Vaseline or now they have silicone lubricants that will not dry out and would probably work better. I think that the plumbers silicone grease might work very good as it is water proof and does not harden and has the ability to creep into tight spaces. I lubed the motor on my 40 in 1990 with Vaseline and it is still working good. I have to exercise it every spring to get it going, but then it works fine all summer. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11183 |
