RG/NJ | -- 04-18-2010 @ 8:36 AM |
My buddy has a 38 and we noticed on the top of the steering tube there is a small hole about 8 inches down from the top. What is it there for?
37RAGTOPMAN | -- 04-18-2010 @ 9:30 AM |
it might be the broken piece that orginally was the steering lock, some people remove them,dos it look like a brokend spot weld ? esp if some one lost the orginal keys and wanted to use the car and used a differrent ignition switch, this is my thought on it, but have none to compare to, can you post a picture of what you are asking about,? hope this helps 37RAGTOPMAN
jerry.grayson | -- 04-18-2010 @ 11:02 AM |
What size hole?
RG/NJ | -- 04-19-2010 @ 1:25 PM |
I can't post pictures. The hole is small. About the size of the tip of an oil can. It is half way up between the steering lock and steering wheel. I thout it might be to lube the rubber bushing but i think all the bushing are at the top of the tube like my 40. Thank you both for your input.
trjford8 | -- 04-19-2010 @ 8:08 PM |
I don't believe that that hole should be there. I've never seen one on a Ford column.
jerry.grayson | -- 04-19-2010 @ 8:21 PM |
Most likely for some after market thing--flashlight holder or something-- not supposed to be there.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1118 |
