autoluke | -- 09-10-2017 @ 5:48 AM |
I have removed the steering assembly on my 41 conv cpe, and noted a 1 3/4" steel collar around the shaft. Need to know the reason for the part. Suggestions ?
42merc | -- 09-10-2017 @ 8:30 AM |
If you are talking about the clamp at the bottom of the mast jacket, it clamps the mast (tube) to the steering gear.
fordv8j | -- 09-10-2017 @ 9:43 AM |
probably for the steering lock to engage into?????
CharlieStephens | -- 09-10-2017 @ 12:21 PM |
Are you talking about Part # 3532 at http://www.vanpeltsales.com/FH_web/flathead_home.htm ? Go to "Parts Drawings" then "Steering Gear" and finally the year of your car. If so, then fordv8j got it right. Charlie Stephens This message was edited by CharlieStephens on 9-10-17 @ 12:24 PM
autoluke | -- 09-18-2017 @ 9:31 AM |
Thanks Charlie #3532 it is !
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11171 |
