1936TWC | -- 08-13-2017 @ 1:22 PM |
Any insights where I could purchase 160 wt gear oil. Thanks.
supereal | -- 08-13-2017 @ 1:37 PM |
140 should be sufficient, and usually will work well in colder climates, and still permit easy gear shifting. If you are trying to reduce leakage, a heavier grade probably won't change it much, if any. The real fix is to replace worn seals and gaskets. Not easy, but necessary.
sarahcecelia | -- 08-13-2017 @ 7:22 PM |
Joe's Antique Auto, Uxbridge, Ma 508-726-3980 Regards, Steve Lee
Drbrown | -- 08-13-2017 @ 9:19 PM |
Last I checked less expensive at Amazon.com and free shipping pending order size. I use StaLube .... 140 in banjo and 90 to help shifting. This message was edited by Drbrown on 8-13-17 @ 9:23 PM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11088 |
