lowgear | -- 08-11-2017 @ 2:02 PM |
I am mounting a radiator in my 41, I put in a flathead V8 out of a 47. I purchased a 3 core aluminum for a 41. I also purchased lower hoses for a 41. The radiator is sitting too low. What do I need to do ?? Thanks
TomO | -- 08-14-2017 @ 8:28 AM |
Call the vendor that sold you the radiator and ask him to provide one with the correct mounting. You paid for a replacement that is supposed to fit, so the vendor should provide one. Tom
trjford8 | -- 08-14-2017 @ 9:36 AM |
Where did you buy the radiator. A reputable supplier will fix the problem. If you bought one of the cheap radiators that I see on e-Bay you may be out of luck. There's a reason why they are cheap.
lowgear | -- 08-20-2017 @ 5:38 AM |
Thanks for the response, the radiator is not sitting too low, someone installed a flex fan that is too big and tall, that wants to chop upper hoses off. I am going to search for the correct fan.
TomO | -- 08-20-2017 @ 7:51 AM |
The correct fan for your 41 Coupe is crank mounted. The 47 fan is mounted on a hub that mounts to the generator mount. You will also need the crank pulley for the 39-41 V-8 along with the fan for a 39-41 Ford. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11077 |
