Bill E Bob | -- 08-04-2017 @ 4:20 PM |
Does anyone have a pic of the attachment hardware for the "Ford" trunk emblem? I have the emblem that was attached to the trunk with HBC double sided tape. The emblem itself gives no clue as to what attachment hardware was on it. Any reference/info is appreciated.
cliftford | -- 08-04-2017 @ 8:03 PM |
This is strictly from memory: I believe they were attached from the inside by 4 #10 or 12 screws running through a channel shaped piece about 3/4" square.
flathead48 | -- 08-06-2017 @ 4:03 PM |
If you are referring to the long emblem that says Ford , there is 3 clips that are soldered on the back side and go through 3 holes in the trunk lid with nuts on the inside.
Bill E Bob | -- 08-07-2017 @ 9:11 AM |
Yup, that's the one. Guess I'll have to get out the soldering iron (or maybe JB Weld?)
supereal | -- 08-07-2017 @ 2:05 PM |
That piece is commonly referred to as the "trunk spear". C&G shows it as 6A-7042544. It is also available as a "third stoplight" piece with the letters pierced. That is HR-7042514. Both are stainless steel, of course. The clips often break loose from the trim, and resoldering them can be difficult, because overheating can damage the finish. I mounted mine with a homemade rubber gasket to prevent damage to my new paint job.
Bill E Bob | -- 08-07-2017 @ 3:23 PM |
Thank you Supereal. Was wondering if there was a gasket under that emblem. I'll figure out something for mounting clips.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11053 |
