engine | -- 07-28-2017 @ 6:04 AM |
My transmission is out of my truck and going to be rebuilt. Can someone tell me what the problem is when it is in 2nd gear and I take my foot off the accelerator it will drop out of gear.
cliftford | -- 07-28-2017 @ 6:31 AM |
My guess: excessive wear in syncro assembly [if it is a 3speed ] or weak or broken detent spring in the shift lever assembly.
engine | -- 07-28-2017 @ 7:27 AM |
Thanks, I am thinking synchro sounds good, the spring on shifter seems strong.
cliftford | -- 07-28-2017 @ 5:47 PM |
Slide the syncro collar back and forth between 2nd and high gear. It should "snap" into place in each gear. If not look for wear or weak springs on the 3 retainers. I'm guessing this may be your problem if it's not the detents in the lever[s]. Of course you need to remove the trans. top. The problem you describe would probably not make any unusual noises. This message was edited by cliftford on 7-28-17 @ 5:50 PM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=11022 |
