Vince49 | -- 04-12-2010 @ 7:11 PM |
I am trying to install a set of fenton headers on my 49 ford flat head engine and can not get the bolts in on the drivers side, to tight. do I have to lift engine out or is there another way.
trjford8 | -- 04-12-2010 @ 8:57 PM |
The front bolts are 7/16 and the rest are 3/8. If you are using 3/8 in the front holes that is probably the reason they will not tighten down.
cbkidder | -- 01-12-2011 @ 5:39 PM |
And I was wondering why my 3/8" bolts weren't tightening at the front ports! Thanks for the info. 36 Roadster brion@cbkidder.com
40 Coupe | -- 01-14-2011 @ 6:39 AM |
check the depth of the holes in the block so you do not try to install bolts that are too long. Damage can be done to the block
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=1094 |
