jimbomac | -- 07-03-2017 @ 5:44 AM |
Does anybody know of a source for a NOS or good rebuilt unit for a 53? Is this the same unit as the 52 or 54? Thanks!
flathead4rd | -- 07-03-2017 @ 6:21 AM |
Try Chris at shoebox-central.com He may be able to help you.
TomO | -- 07-03-2017 @ 9:50 AM |
Try Baxter Ford parts in Lawrence, KS. He can rebuild yours if necessary. Contact them at 785.842.9256, (fax) 785.842.2810 or email at baxterford@sunflower.com Tom
supereal | -- 07-03-2017 @ 12:41 PM |
We have ours done by Bob's Speedometer in Michigan. You send them the speedometer and they will check it an quote the repair cost. They also have replacements in stock. They do clocks, tachs, gauges, gas sending units, and cruise controls. They also buy those items if you have spares. 1-800-592-9673
JT Ford | -- 07-03-2017 @ 2:46 PM |
Baxter Ford does not repair speedometers any longer. Chris @Shoebox Central repaired my l949 Ford speedo. In and out 5 days! Good prices.
sarahcecelia | -- 07-03-2017 @ 8:16 PM |
Look in Hemmings magazine
sarahcecelia | -- 07-03-2017 @ 8:17 PM |
Hemmings lists companys that rebuild them. Regards, Steve Lee
Big Red 51 | -- 07-06-2017 @ 5:37 AM |
Some want about $250 to repair if they can find parts. I found a whole '52 instrument cluster on ebay last week with a working speedo. In fact all the instruments worked, all for $60. My '53 speedo shaft broke coming back from Chantilly. Be sure and oil the speedo. The '53 oil hole is on top of the cable threads and can't see with cable scr*w*d in. Popped the "new" one in and works good. Don PS Baxter told me last week that he is only doing transmissions. No instruments. This message was edited by Big Red 51 on 7-7-17 @ 5:36 AM
DJ | -- 03-04-2018 @ 5:03 AM |
Be sure and oil the speedo. The '53 oil hole is on top of the cable threads and can't see with cable scr*w*d in. I plan to have my 51 speedometer rebuilt, but also want to make sure cable/housing are in good shape and lubed. The “hole on top of the cable threads”. Is that on the speedometer or the cable? Also, what type of lube would you recommend?
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10923 |
