jimbomac | -- 07-01-2017 @ 7:04 AM |
What is the correct oil to use in a 1953 Borg Warner OD unit? There are a lot of conflicting opinions going around. Thanks!
carcrazy | -- 07-01-2017 @ 2:34 PM |
The oil I use in my '53 O/D transmission is NAPA SAE 90W Mineral Gear Oil API GL-1. It comes in 1 gallon containers under part no. 65-201 and sells for about $15. Your local store may not have it in stock but they can order it for you and have it in about one day.
jimbomac | -- 07-01-2017 @ 6:18 PM |
Thank you! How long have you been using it? Do you use the same oil in your 3 speed?
carcrazy | -- 07-01-2017 @ 7:34 PM |
I have been using this oil since I got this car about two years ago. Yes, I use the same oil in the 3-speed. The two units share a common oil supply chamber even though there are individual fill and drain plugs for each.
Drbrown | -- 07-01-2017 @ 11:04 PM |
As carcrazy notes, the lubricant chambers in the Ford Transmission/OD units are connected. I understand that those Trans/OD units were manufactured by Ford based on BW OD designs. My BW R10 OD is a separate unit from the transmission. Many years ago a former BW service/repair man told me use 140 in the BW OD. I use Sta-Lube brand purchased from Amazon. I could use 140 (GL-4) in my tranny but prefer the lower viscosity 95 for better shifting in my northeastern temperature climate.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10919 |
