twostickmutt | -- 06-26-2017 @ 8:15 AM |
i am putting the bypass oil filter canister on my 59 a and was wondering if it goes on the front of the head or rear of the head or if it makes a difference. thanks.
supereal | -- 06-26-2017 @ 9:29 AM |
They mount toward the front on the driver's side. This makes changing the filter cartridge easier. Be sure to check to see if the output line has a restrictor in place. Otherwise the oil pressure will be affected'
twostickmutt | -- 06-26-2017 @ 10:00 AM |
thanks supereal. yes i have the fitting with the small orfice in it. i thought that went into the input side of the filter ?
ford38v8 | -- 06-26-2017 @ 10:24 AM |
I think Super meant the engine output line, leading to the filter input. A restrictor on the filter output would theoretically equalize pressure within the housing, nullifying flow through. Alan
twostickmutt | -- 06-26-2017 @ 10:54 AM |
thanks alan after i thought for a minute that's what he meant. i'm good to go. thanks again for everybody's help.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10903 |
