coupeman | -- 06-12-2017 @ 4:05 PM |
I got my rear brake shoes in place, E-brake cable installed and upper spring attached to the shoes only to realized the shoe retainer spring were not in place (oops)do I start from scratch or is there a way to attach them without taking everything apart?
TomO | -- 06-13-2017 @ 7:06 AM |
If you are asking about your 48 Coupe with original brakes, you may be able to spread the shoes enough to get the spring on, but I would remove the upper spring and slide the shoes into the clips. Tom
coupeman | -- 06-13-2017 @ 10:36 AM |
Thanks Tom, I have a different spring clip setup than your diagram shows, but I was able install them with a different technic.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10859 |
