39FORDPU | -- 06-11-2017 @ 3:50 PM |
I want to install a tach in my 1939 P.U. The wires go to the + and - on the coil, I only see one wire coming out of the top of the coil where do I hook up the wires? The truck is all stock. Thank You.
TomO | -- 06-11-2017 @ 6:07 PM |
If you have the coil mounted on top of the distributor, the condenser mount is the pick up point for the contact points. I do not know how your tach needs to be connected, but when I connect my dwell meter, the - lead goes to the condenser mount and the + lead goes to ground. Tom
supereal | -- 06-25-2017 @ 1:29 PM |
I see the Sun tachs and senders at swap meets now and then. Most of us used them back in our hotrod days. They are excellent for 6 volt vehicles.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10854 |
