drkbp | -- 06-05-2017 @ 7:53 PM |
I finished rebuilding one of the Stromberg 97's that I had been running on my '35 Cabriolet. I made a couple comments about it a month ago on anther thread. It is now back on the car and I have some miles on it. Easy start and quick on the acceleration. I had forgotten how smooth that carburetor could run. Should have done it a long time ago. It had a #63 Power Valve and a pair of .045 jets in it. I put a new #65 Power Valve and new .045 jets. Could have used the old jets I guess. Also put in a new pump inlet check valve with the rest of a rebuild kit. The hardest time I had was removing the old #63 power valve and clearing a blockage of one of the pump discharge nozzles. The rest was just getting that carburetor clean. I do recommend getting a Stromberg jet wrench. A very helpful article on the Detroit-Lubricator and the Stromberg 97 is at the following link: http://www.flatheadv8.org/stromberg.htm Actually, the 97 is a fairly simple unit and I'm going to go ahead and rebuild the other 97 as a spare. I had it on the car while I was working on the first one. It surely has a bad piston and trash in it so I will go ahead and fix it now while the bench is set up and I can remember how it's done. Getting old over here! Thanks for the comments on a previous thread a month ago. The power valve wasn't closing and allowed too much fuel at idle. Ken in Texas
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10835 |
