jamesmundstock | -- 06-02-2017 @ 3:25 PM |
I think the one piece guides with valves and keepers from a 8BA will work in a 59AB. Can anyone verify this? Thanks.
len47merc | -- 06-02-2017 @ 4:18 PM |
Yes - from personal experience they will and they are more robust and a better choice than the stock configuration. Steve
jamesmundstock | -- 06-02-2017 @ 5:49 PM |
Thanks for the confirmation
cliftford | -- 06-02-2017 @ 7:47 PM |
I agree, and if you are not using adjustable lifters, they make it a lot easier to set the valve clearance.
TomO | -- 06-03-2017 @ 7:04 AM |
If you use the 8BA type valves, make sure that you use the seals on the intake valves. Tom
jamesmundstock | -- 06-03-2017 @ 8:54 AM |
I have worked on cars for years but this is my first time on a flathead. Removing the valves and guides is a real pain even with the right tool. Thank goodness my guides were not stubborn. I am definitely going to put the 8BA components back in with the adjustable lifters.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10821 |
