Fhower | -- 05-31-2017 @ 1:50 PM |
I have a 1941 Super Deluxe Convertible that has a vent window gear that is missing a few teeth. I bought a repair kit from C&G. I was told that remove the rivets and the assemble will drop out. I have removed the rivets and no luck. The appears to be a bolt and nut that attaches to a sheet metal bracket in the door. The nut is pretty well rusted and hard to get to. Has anyone removed the vent window regulator/assembly?. Am I going about this wrong? This message was edited by Fhower on 5-31-17 @ 1:51 PM
murphy1941 | -- 07-09-2017 @ 7:53 PM |
I have also 1941 super deluxe with vent that came attached incorrect. Is there any chance that you can send me a diagram or picture of how assembly should be made. Ford103041@gmail.com thk u
supereal | -- 07-22-2017 @ 2:53 PM |
We use the gear kit from C&G. It includes the gear, spring and rivets. The original rivets must be drilled out and the body of the assembly separated. The kit is for 41-48, part #11A-7023402. The job takes time and patience. A very good way to get an unfamiliar job completed is to take photos of the part as you disassemble it so you will have an understanding of what goes where. This message was edited by supereal on 7-22-17 @ 2:56 PM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10813 |
