Bob56 | -- 05-29-2017 @ 2:33 PM |
Before I switch back to the original style coil from the after market one is there a way to test the ignition resistor under the dash for functionality
40 Coupe | -- 05-30-2017 @ 3:54 AM |
Place a digital ohmmeter across the resistor should be approximately 0.5 Ohm. Clean both of the mountings ears and use clean brass screws for electrical mounting.
JM | -- 05-30-2017 @ 8:31 PM |
You could also check that resistor by temporarily placing it in a 6V test circuit to see if functions correctly under load and reduces circuit voltage as it is designed to do in an ignition system. John
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10801 |
