myblack46 | -- 05-28-2017 @ 9:44 AM |
My 46 ford V/8 has a problem. I have a knocking noise at idle and low rpm after warmed up. However, I can remove the oil filler cap and hold my hand over top and knock goes away. I recently had distributor out to R & R points. Did not hear knock before. What could it be?
shogun1940 | -- 05-29-2017 @ 5:12 AM |
Well i always go to the last repair to see if something is wrong. That being said i would use wooden dowel or long screwdriver to listen to where the noise is coming from. Also you can cut a piece of hose and use that to isolate where the noise is coming from.
TomO | -- 05-29-2017 @ 7:30 AM |
Some fuel pumps make a knocking noise, so I would start listening near the pump, using the method shogun1940 suggested. Tom
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10798 |
