jamesmundstock | -- 04-30-2017 @ 8:05 AM |
I have my distributor off to put a Pertronix ignition in it. On the mounting surface is a cavity where the vacuum ports is. My rubber in the cavity crumbled. I can't find this rubber seal anywhere; Bob Drake, Dennis Carpenter, etc. Any suggestions? The cavity looks too large and deep for a conventional O-ring. Thanks in advance for your response.
fordy8ford | -- 04-30-2017 @ 8:11 AM |
I think it comes as part of the gasket kit.
jamesmundstock | -- 04-30-2017 @ 8:24 AM |
The gasket kit I received from Bob Drake did not have it. Are there any other kits that do?
TomO | -- 04-30-2017 @ 8:36 AM |
Try this vendor http://www.joesantiqueauto.com/catalog.pdf Tom
jamesmundstock | -- 04-30-2017 @ 9:51 AM |
Great. I went to the site and found it and it is a pert of their gasket kit. Thanks.
ken ct. | -- 04-30-2017 @ 1:32 PM |
I have them divorced from a kit. ken ct. You must remove old one along with the tubeular like rivet to install new one. Pry out with a small screwdriver or run a tap into the rivet and try to remove that way. Ive changed dozens of them. 1-203-260-9780 or email. PS this part never or now comes in a gasket set.It is sold or sold as a separate part 2 pieces the rubber seal and the special short hollow rivet like piece in brass. ken ct. Evedidently no longer available. I have some of them from when they were available. ken ct. This message was edited by ken ct. on 4-30-17 @ 5:29 PM
ken ct. | -- 04-30-2017 @ 11:09 PM |
I have them your email ronsallygrass@mac.com will NOT go through ????? ken ct .
GK1918 | -- 05-02-2017 @ 5:39 AM |
Too late but I was going to say hardware store 2 cent 0 ring thats what I use......sam
40topless | -- 05-11-2017 @ 5:48 AM |
Don't be scared to have an extra in your car that's tuned up with points in it. I have had 2 with pertronix go out. Back to points runs like a champ. My 2 cents.
ken ct. | -- 05-11-2017 @ 7:29 AM |
I stil have some of the proper rubber seal part W/hollow special rivet that goes with it. $ 8.00 plus $ 2.50 shipping. ken ct. 1-203-260-9780 cell.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10722 |
