philipswanson | -- 04-23-2017 @ 11:58 AM |
Does anybody know if there is an aftermarket AM/FM radio that bolts into the 40 and runs on 6V/Negative ground system? I don't want to switch to 12v. I could use a converter that enables you to run a 12 radio on 6 volts with polarity switched? Thanks, Phil Swanson This message was edited by philipswanson on 4-23-17 @ 5:29 PM
Kens 36 | -- 04-23-2017 @ 5:55 PM |
Philip, Do you have an existing stock radio in your car? There are vendors who can add an FM module to an existing radio. Ken
philipswanson | -- 04-23-2017 @ 8:30 PM |
No I do not have a stock radio. Anybody know a source for a tested good one??
TomO | -- 04-24-2017 @ 6:59 AM |
I am not sure if you just made a typo, but your Ford should be POS ground. You do not need a working radio, if you want to have a FM tuner. There are modules that provide the AM/FM radio that can be hooked up to the original 1940 controls in an original 1940 case. A working 1940 radio will cost more than $300 and you can buy a core for much less and have the conversion made. I have no idea of how much the conversion will cost and can't refer you to a vendor that does this. Tom
philipswanson | -- 04-24-2017 @ 1:17 PM |
Yes, it was a typo. Yup, a positive ground, 6 volt system. I would gladly pay $300 for a nice working radio. Anybody know a source for a decent 40 Ford stock radio?
trjford8 | -- 04-24-2017 @ 2:34 PM |
Keep an eye out on e-Bay. hey show up there occasionally. Also if you are a V-8 Club member you can run a free want ad in the V-8 Times. The free ad coupon came with the last mailing of the Times and roster
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10702 |
