bobmg53 | -- 04-05-2017 @ 2:11 PM |
Have two different heads. Both came off same engine. One has shallow combustion chamber other has deeper chamber. Which one should be used for flat head pistons.
40 Coupe | -- 04-05-2017 @ 2:24 PM |
If you can not post a photo can you post the complete part number from the head?
39 Ken | -- 04-06-2017 @ 6:30 AM |
Just an opinion, I believe that the flat top pistons can be used with either head. Domed pistons would need the deeper combustion head. However, 40 coupe's recommendation can give you the whole story.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10654 |
