tommyleea | -- 04-04-2017 @ 8:30 AM |
Working on my distributor now. Should the vacuum advance unit hold vacuum, or just move with vacuum?
ken ct. | -- 04-04-2017 @ 10:27 AM |
I assume no vac.@ dist means it just doesn't function till ported vac is present. Vac is diff than vac. @ the manifold. The dist. will not work properly if connected to manifold vac. Don't quite understand your ques. ken ct. This message was edited by ken ct. on 4-4-17 @ 10:30 AM
tommyleea | -- 04-04-2017 @ 5:47 PM |
I have the vacuum advance unit removed, and was going to apply vacuum to test it.
40cpe | -- 04-05-2017 @ 6:32 AM |
I have one I tested and it holds vacuum with a mity vac until I release it.
flathead4rd | -- 04-05-2017 @ 6:44 AM |
If it doesn't hold vacuum it has a leak in the diaphragm. Get a new one.
tommyleea | -- 04-05-2017 @ 2:17 PM |
Thanks, on order..
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10652 |
