37 Coupe | -- 03-15-2017 @ 7:36 AM |
What did Ford offer for the 1953 Ford F-100 with the V-8 for an overdrive? Was it available as a three speed column shift transmission or just on the four speed floor? Thank You.
trjford8 | -- 03-15-2017 @ 7:41 AM |
It was the three speed column shift. The four speed floor shift just had 4 speeds rather than three. High gear in a four speed was simply the one to one ratio.
37 Coupe | -- 03-15-2017 @ 7:53 AM |
Next question is if it was the same as the passenger car 3 speed overdrive and can the solenoid be adapted to a 12 volt conversion?
carcrazy | -- 03-16-2017 @ 8:08 AM |
The 6V overdrive solenoid will have to be replaced by a 12V solenoid. They are available new from Randy Rundle at Fifth Avenue Antique Auto Parts. His number is 785-632-3450. New ones are a bit pricy. Used ones can sometimes be found at swap meets but may not work for very long.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10592 |
