ken ct. | -- 03-01-2017 @ 4:40 AM |
Where is vacume picked up when a 41 block which has the vacume connection at the intake manifold. But using a crab dist which has a vacume passage on the cover and a I assume a passage in the block. This is hard to explain. There is no line connection hole on a crab dist need help on this one. ken ct. I assume hes using a spacer plate to move the crab out more.The line from the manifold runs to a boss on the helmet dist itself. There is no boss on a crab one,where is the line hooked up for a crab. This message was edited by ken ct. on 3-1-17 @ 5:19 AM
kubes40 | -- 03-01-2017 @ 5:32 AM |
You need to install the two bolt timing gear cover. That has the threaded port for the vacuum line (fitting).
ken ct. | -- 03-01-2017 @ 7:38 AM |
Thank you ken ct.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10556 |
