tommyleea | -- 02-16-2017 @ 6:30 PM |
It is me again. 53 Ford Flathead Ford Carb, series 94. I was testing the accelerator pump circuit prior to assembling the carb. The check ball seems to be working correctly, and I get fuel coming out of the discharge nozzle well. I assembled the discharge nozzle, idle tubes, and main nozzles. I put some fuel in the accelerator pump well, and worked the pump up and down. I got some seepage out of the accel pump discharge nozzle, but not a solid squirt like I am used to. I have not really tested one like this before, but do you think this is normal, or should the fuel spray out? The carb is not fully assembled yet.
ken ct. | -- 02-16-2017 @ 9:02 PM |
Yes it should come out in a fairly strong stream from the "Y" shaped squirter. Poke a thin wire through it and then blow it out good with compressor blow gun. Their are a type of style with the hole @ the very bottom of each leg,these are hard to poke a wire through the hole goes straight up. Others have holes at an angle on the bottom,these are much easier to get a wire through. I have a draw full of them I will trade you 1 for 1 if you want to plus shipping for a clean one w/canted holes. ken ct pm,email or cell 1-203-260-9780
tommyleea | -- 02-18-2017 @ 7:28 AM |
Thanks for the advice and offer Ken..I did get it cleared out..working fine now..Thanks again.
ken ct. | -- 02-18-2017 @ 9:38 AM |
Good job Tommy. Its the tiny holes that screw you up big time. ken ct.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10520 |
