Joeellsasser | -- 02-16-2017 @ 2:25 PM |
I have a 34 that has a seepage from the head in the spark plug area. It was fix with JB weld. I would like to purchase and replace the head. Who makes a OEM style head and where can one be purchased. I'm not looking to replace it with an aftermarket performance style. I want to keep it original as possible.
MG | -- 02-16-2017 @ 2:55 PM |
I got the heads for my '34 at Kearney Pattern Works in San Jose, CA They advertise in the V8 Times.... Click on this link > http://kearneyfoundry.com/ REPLICA CASTINGS: "Kearney Pattern Works & Foundry manufactures exact duplicate cylinder heads for 1933-1936 Ford V8's, as well as a finned "Hot Rod" version. We manufacture exact duplicate finned cylinder heads for V-12 Lincoln flatheads, as well as a custome 3 carburetor intake manifold. These products are commonly sold to individuals who restore cars and require the very best when entering shows." This message was edited by MG on 2-16-17 @ 3:24 PM
MG | -- 02-16-2017 @ 3:41 PM |
Pictures of the cylinder heads I got from Kearney Pattern Works attached below:
MG | -- 02-16-2017 @ 3:42 PM |
And, the left head....
1934 Ford | -- 02-16-2017 @ 5:10 PM |
I finally replaced my last original aluminum head with a cast iron one with aluminum paint. Looks great, but I know it's not right. Anybody know approximate cost of theses new heads? 1934 Ford's since 1972
MG | -- 02-16-2017 @ 5:14 PM |
I paid Kearney $1500.00 for the set I have on my '34 back in 2015....
Joeellsasser | -- 02-16-2017 @ 6:17 PM |
Does the anti freeze leach thru the aluminum heads? The area doesnt look like it is cracked. Second cylinder above the spark plug. This message was edited by Joeellsasser on 2-16-17 @ 6:19 PM
MG | -- 02-16-2017 @ 6:31 PM |
"Does the anti freeze leach thru the aluminum heads?" I've never heard of such a thing. Looks like you might have some seepage around/from the stud above that cylinder....
40 Coupe | -- 02-17-2017 @ 12:49 PM |
I agree it is most likely seepage from the stud above changing the head will not correct this. I would suggest some engine cooling system sealer like Bars Leak.
Joeellsasser | -- 04-17-2017 @ 1:58 PM |
Update, note leak in the sparkplug area, on the other head there was a leak dead center between plugs on the flat part of the head. Yes the aluminum head has corroded or had two bad castings.
Joeellsasser | -- 04-17-2017 @ 1:59 PM |
I install new new heads this weekend and they look great, even have the Ford script on them.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10517 |
