roadster36 | -- 02-15-2017 @ 1:29 PM |
I know I read somewhere that new senders for 1933/1934 Ford oil chex gauges were available. Does anyone know the source for these. Thank you -Dennis
40 Coupe | -- 02-16-2017 @ 6:27 AM |
You may have read the form on fordbarn.com. I believe the person looking was in Australia and found something locally. The sending unit they found is not locally available in the states. It should not be too difficult to find a pressure switch that changes position at a low pressure, but to have the similar appearance also may be difficult. You will also need it to be either Normally Open or Normally closed depending upon what the oil chex needs. This message was edited by 40 Coupe on 2-16-17 @ 9:10 AM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10510 |
