jretter | -- 02-12-2017 @ 7:54 PM |
Is there a way to tell the difference between original and reproduction 34 Ford bumpers?
ford38v8 | -- 02-12-2017 @ 11:10 PM |
Give it a good swift kick. If it's original, it'll knock you on your... But, if it's a repop, it'll bend. Alan
jretter | -- 02-14-2017 @ 9:05 PM |
And I should probably do it when no one is looking? Would prefer a "non-destructive" test, if possible.
trjford8 | -- 02-15-2017 @ 7:49 AM |
Generally the originals have some stamped markings on the back. usually letters like "U" or "C". You will find no stamped marking on the back of the repos.
jretter | -- 02-15-2017 @ 3:01 PM |
Great. This is helpful. Thanks.
1934 Ford | -- 02-18-2017 @ 3:37 AM |
I had reproductions with the "C" stamped in them. Is there a test with magnets? 1934 Ford's since 1972
trjford8 | -- 02-18-2017 @ 7:57 AM |
Both originals and repos are made of steel, so a magnet test will not work. The originals are spring steel and the repos are not. I don't recall seeing repos with markings on the back. Having a letter on the back must be something that has recently been done on repos.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10501 |
