Fhower | -- 02-07-2017 @ 6:29 AM |
Hello I am new to the EV8 and I have a four wire heater harness and switch that were not connected. Does anyone have the wiring instructions.
TomO | -- 02-07-2017 @ 8:32 AM |
If you look carefully at the back of the switch, you will see colored dots next to the terminals. The colors on the dots correspond with the wire colors. The black wire goes on the terminal with the black dot and connects to the power source. The yellow, red,brown and green wires connect to the terminals and to the heater. Here is a link to a wiring diagram http://www.flatheadv8.org/91A-18457%20Heater.pdf Tom
Fhower | -- 02-09-2017 @ 9:02 PM |
Tom, Perfect! Thanks so much. Fred
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10483 |
