tommyleea | -- 01-13-2017 @ 7:35 PM |
53 flathead oil pan gasket. Getting ready to install the oil pan. I have the rope seals seated in. The two piece oil pan gasket covers over the rope seals, that are in the block. Am I to trim the oil pan gasket where they meet the rope seals? It doesn't seem right that they would go over the top of the rope seals.
tommyleea | -- 01-14-2017 @ 7:25 AM |
After further research, it appears that if the rope seals aren't flush in their mounting, I should trim the pan gasket, and if the rope seals are flush, then put the pan gasket over them. Off to work.
flathead4rd | -- 01-14-2017 @ 8:09 AM |
I think you should trim the rope seal about 1/16" of an inch proud and not flush with the block. Then install the oil pan seal as is. Someone correct me if that seems wrong but that's the way I do it..
supereal | -- 01-17-2017 @ 2:38 PM |
Yes, that is the way. The ends of the rope seals must stand above the gasket surface to be compressed when the pan is tightened. Otherwise, it ill nearly always produce a leak.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10415 |
