Steves46 | -- 11-06-2016 @ 9:58 AM |
I need to confirm the order of installation for the fuel pump assy on my 59AB: 1) Drop in push rod 2) Install fuel pump stand gasket. 3) Install oil baffle 4) Install oil fill tube with fuel pump attached. Is this correct? I am not clear if the oil baffle goes on before or after the gasket. Appreciate the help. Steve
ken ct. | -- 11-06-2016 @ 1:29 PM |
You have it correct the 5" baffle tube (for cast iron intake must go in after the gasket) as the flare at the top must go in the recess on the bottom of the stand. Lots of guys do it backwards resulting in an oil leak there. kuddoos to you. ken ct.
Steves46 | -- 11-06-2016 @ 2:24 PM |
Thanks Ken.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10246 |
