wisc40ford | -- 11-03-2016 @ 8:25 PM |
I am currently restoring a 40 Ford coupe and am now working on the glass. Question I have is this......should I use a weatherstrip contact cement when installing the vent seal into the window frame???? I would think this would help hold the seal into place. Would a small bead along the seal channel be the right thing to do??? Thanks in advance for any toips on this procedure. Steve
19Fordy | -- 11-04-2016 @ 9:35 AM |
No, Steve. The glass setting tape is all you need. Otherwise you will be in trouble if you ever have to replace the glass. Check Fordbarn also for replies.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10234 |
