tommyleea | -- 10-27-2016 @ 6:49 AM |
I am getting ahead of myself here, because I am still building my engine. However, I purchased a 53 Ranchwagon that had been sitting many years. There was not a battery in it. Engine bay looks original. My question is, how do I know if this is still the old 6 volt positive ground system, or if it has been changed over to a 12 volt negative ground system? I can't see a difference in the battery cable end sizes. What items do I look for to verify? Thanks
40cpe | -- 10-27-2016 @ 7:06 AM |
Check the voltage regulator for voltage written on it. It might be on the back. I think headlight sealed beam bulbs had the voltage on the back of them.
tommyleea | -- 10-27-2016 @ 7:24 AM |
Thanks
trjford8 | -- 10-27-2016 @ 7:42 AM |
The number on the tailamp bulbs will also tell you if they are 6 volt or 12 volt.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10206 |
