40fordor | -- 10-26-2016 @ 2:29 PM |
I cannot get the gas tank to clear the side rails. It is very close to dropping down but about 1/16 inch or less interference on the passenger side. Suggestions? The car is a very original 40 Ford.
alanwoodieman | -- 10-26-2016 @ 5:26 PM |
with a 40 the gas tank must be forced over and up on the drivers side in order to gain clearance for the pass side to drop down. it is a very tight fit!!
MICHV8 | -- 10-27-2016 @ 5:06 AM |
passenger inner fender panel may need to be "persuaded" a tad
40fordor | -- 10-27-2016 @ 5:27 AM |
Thanks for the replies. I am doing what was recommended and it is still not quite enough. On the driver side I have pried the inner fender panel to give more room to slide the tank. It appears that a spot weld prevents bending the inner panel any more at the rear. Don
trjford8 | -- 10-27-2016 @ 7:45 AM |
You usually need to use a pry bar for some friendly persuasion to get it to clear the rail.
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10203 |
