jyakel | -- 10-17-2016 @ 3:59 PM |
Gentlemen, I have a '50 Ford Custom Fordor with a Flathead V8 and a standard 3 speed tranny with OD. If I chose to convert my Ford to a 12V system does that mean I must change out all the OD components to 12V; solenoid, relay, and kick down switch? Also, if my Ford is stock do I have a Borg Warner R-10-R12 OD system? Please advise. John
40cpe | -- 10-17-2016 @ 5:45 PM |
Your kick down switch isn't voltage sensitive. The governor works on 6 or 12 volts. The relay will need to be changed to 12V. A lot of people report that the 6V solenoid has worked for a long time on 12V, others feel more comfortable changing it to 12V. Your call on the solenoid.
jyakel | -- 10-18-2016 @ 4:54 AM |
Okay, that's what I need to know. Thank you for your response. John
56MarkII | -- 10-21-2016 @ 8:57 PM |
And those solenoids are exxxxxpensive! Eeeeek! It's probably an R-10. Thats the animal that's in my Merc. sedan This message was edited by 56MarkII on 10-21-16 @ 8:58 PM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10178 |
