H Mike | -- 10-17-2016 @ 2:50 PM |
on initial start my 1941 Ford starts right up, but after warming up it won't start til it's cooled down. Where should I start to correct this ?
alanwoodieman | -- 10-17-2016 @ 3:03 PM |
check your spark--should jump an arc of 1/2" and be blue in color. flatheads are notorious vapor lockers--never touch the gas pedal with a warm engine start--try to start and then if necessary open throttle just a little. if you have good spark, and are not flooding out engine then look for a gas leak from the power valve that is flooding engine. let us know what you find
fordv8j | -- 10-17-2016 @ 5:37 PM |
Our 38 was the same way, tried replacing everything,didn't help, finally called Dick Flynn, he asked what coil I was using, I'm using a 59-ab distributor with a round coil, then he asked if I was still using the resistor under the dash, I was, he said to by-pass it by putting both wires on same side, this puts 6 volts to the coil, the round coil needs 6 volts, the other ones much less,,this has been quite a while back, it has never failed to start since....no point problems
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10177 |
