3949tl | -- 10-08-2016 @ 4:20 PM |
What's a good way to slightly lift and support the engine in oder to replace the water pump on a 40?
TomO | -- 10-08-2016 @ 5:28 PM |
Place a thick, wide board under the oil pan to distribute the load and use a jack to raise the engine. You should remove both motor mount nuts when you do this. Tom
3949tl | -- 10-08-2016 @ 6:23 PM |
Thanks. I know that this isn't rocket science and this confirms my thought as how to do it.
CharlieStephens | -- 10-08-2016 @ 11:04 PM |
The rocket science part is knowing there is a bolt that is only visible/accessible through the part of the water pump where the hose is attached. Thanks to Mac VanPelt you can see this at: http://www.vanpeltsales.com/FH_web/flathead_waterpump-removal.htm Charlie Stephens This message was edited by CharlieStephens on 10-8-16 @ 11:07 PM
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10143 |
