36fordor | -- 10-04-2016 @ 6:46 AM |
Did original 36 Ford have any fuses? If so where? Thanks.
ford38v8 | -- 10-04-2016 @ 10:21 AM |
One fuse, under the dash, above the steering column. Mounted on a fiber board next to the ignition resister. Serves all the lights interior and exterior. A second fuse only if there is a radio installed, will be an inline fuse to the radio only. (Don't touch the ignition resister while the engine is running, or you won't forget the experience.) Alan
Topic: | https://www.earlyfordv8.org/forum/viewmessages.cfm?Forum=18&Topic=10133 |
